    Mar 2011
    Paris, France
    Hello
    I tried opening the following file in Corel VideoStudio X5…
    c:\>ffprobe.exe -i input.mov
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'input.mov':
      Metadata:
        major_brand     : qt
        minor_version   : 537331968
        compatible_brands: qt  CAEP
        creation_time   : 2014-07-04 14:02:36
      Duration: 00:00:12.75, start: 0.000000, bitrate: 11548 kb/s
        Stream #0:0(eng): Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yu
    vj420p(pc, smpte170m), 640x480, 9950 kb/s, 29.97 fps, 29.97 tbr, 30k tbn, 60k tb
    c (default)
        Metadata:
        Stream #0:1(eng): Audio: pcm_s16le (sowt / 0x74776F73), 48000 Hz, stereo, s1
    6, 1536 kb/s (default)
        Metadata:
    … but it can't import that type of file.
    Next, I tried to convert the container from MOV to MPEG to see if it could work (ffmpeg.exe -i input.mov -c:v copy -c:a copy -shortest -f mpeg output.mpg), but besides the fact that ffmpeg displayed a bunch of error messages, the MPEG file didn't play in VLC:
    [mpeg @ 0031c8a0] packet too large, ignoring buffer limits to mux it
    [mpeg @ 0031c8a0] buffer underflow st=1 bufi=2531 size=3884
    What would be the right way to convert the MOV files so they can be edited in VisualStudio? Do I need to reencode and introduce loss in the process?
    Thank you.
  2. You could try running the mov file through tsMuxer. See if it throws an error. Upgrading to X7 might help too.
    Try mp4 instead of mpg.
    Mar 2011
    Paris, France
    Thanks, but still no go:
    c:\>ffmpeg.exe -i MVI_5908.mov -c:v copy -c:a copy -shortest -f mp4 MVI_5908.mp4
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'MVI_5908.mov':
      Metadata:
        major_brand     : qt
    c (default)
        Metadata:
        Metadata:
    File 'MVI_5908.mp4' already exists. Overwrite ? [y/N] y
    [mp4 @ 003ec8a0] Using AVStream.codec.time_base as a timebase hint to the muxer
    is deprecated. Set AVStream.time_base instead.
        Last message repeated 1 times
    [mp4 @ 003ec8a0] Could not find tag for codec pcm_s16le in stream #1, codec not
    currently supported in container
    Output #0, mp4, to 'MVI_5908.mp4':
      Metadata:
        major_brand     : qt
        encoder         : Lavf55.44.100
        Stream #0:0(eng): Video: h264 ([33][0][0][0] / 0x0021), yuvj420p, 640x480, q
    =2-31, 9950 kb/s, 29.97 fps, 30k tbn, 30k tbc (default)
        Metadata:
        Stream #0:1(eng): Audio: pcm_s16le (sowt / 0x74776F73), 48000 Hz, stereo, 15
    36 kb/s (default)
        Metadata:
    Stream mapping:
      Stream #0:0 -> #0:0 (copy)
      Stream #0:1 -> #0:1 (copy)
    Could not write header for output file #0 (incorrect codec parameters ?): Error number -22 occurred
    Mar 2011
    Paris, France
    Problem solved: Just had to convert audio to MP3 thusly, and Corel imported the file OK:
    ffmpeg.exe -i MVI_5908.mov -c:v copy -c:a  libmp3lame -ab 128000 -ar 44100 -ac 2 -shortest -f mp4 MVI_5908.mp4
    Thank you.
